Home Page Forums Technical Discussion Install firmware of iPlay 30 Pro on iPlay 30?
Viewing 10 posts - 1 through 10 (of 12 total)
2021-01-13 18:59:35
Replies: 11 | Views 6464 | Favorites: 0 | Subscriptions: 3
Hi community,
I just wonder since there is a firmware update for the iPlay 30 pro, whether this can also be installed on the iPlay 30?
Or this is rather something not to mess with?
Thanks a lot for some feedback.
Best,
Domi
2021-01-14 02:03:27
Hi.
I just updated it in iplay30 pro, but the date of the security part has not changed. It should be to correct some errors it would be nice to update from time to time and not make the equipment obsolete.
2021-01-14 16:52:42
thanks @joaqui for your reply.
Just to make sure: did you install the iplay 30 pro firmware on the iplay 30 or on the iplay 30 pro?
I am wondering, whether I can install a PRO firmware on a non-PRO (normal iplay30) tablet. Or is this something that might break or brick the tablet?
thanks for clearing up on this.
Best,
Domi
2021-01-15 03:36:02
Hi Domi.
I update in Pro, not if it were also valid for the other one, I would indicate it in the title, it is very delicate, do not try until you are sure, ask where you bought it.
2021-01-15 03:38:35
2021-07-01 15:21:25
Can I install my iplay 30 to iplay 30 pro firmwares?
2021-07-03 13:32:48
Yes. Did it yesterday. Is working
2021-08-19 12:04:55
Anybody did it success?
I plan to install this IPlay30Pro firmware iPlay30(T1012E)-EN-20210603
Alldocube iPlay30 Pro(T1012E) firmware download
to my IPlay30.
Do it have problem?
Thanks
2021-08-21 01:00:40
Quote #7F by @Firstaldo:
Hi, are there any issues after flashed with iplay 30 Pro firmware?
2021-08-28 04:07:04
#10F
I tried the new version (iPlay30(T1012E)-EN-20210603). It does not work . There is always an error message.
(my Iplay30 is not a pro !!)
