Home Page Forums General Discussion problem with iwork 10pro windows can not read sd card error code 10
Viewing 10 posts - 1 through 10 (of 15 total)
2019-02-22 23:39:15
Replies: 14 | Views 8951 | Favorites: 0 | Subscriptions: 2
my new tablet  after two week , sd card can not be opened on widows, i reset windows also problem present  i tried alot of ideas but the same error .
SD card identified on android no problem in android.
please how can i solve this problem?
2019-02-23 15:00:46
please tell me your serial number of tablet.
if your tablet serial number begin with i1002,i think you can try this drivers for i1002 windows os:https://mega.nz/#!vXInRAqJ!hxTKDxX13OZthDKVxhSzMf7qok4aWC4EyBeM-t5uMUE
2019-02-24 02:17:40
please tell me your serial number of tablet. if your tablet serial number begin with i1002,i think you can try this drivers for i1002 windows os:https://mega.nz/#!vXInRAqJ!hxTKDxX13OZthDKVxhSzMf7qok4aWC4EyBeM-t5uMUE
thank you for rapid reply
I already downloaded file but I have tried double driver to restore drivers there is missed .ini file .
which is appropriate application for restoring it?
2019-02-24 21:20:50
My serial number start by i1002 I have been tried to restore this drivers manually but I failed pls can you tell me which app used for this backup?
Or if you can upload double driver backup?
Thank you
2019-02-26 11:35:22
for i1002 ,you also can try to reinstall windows os :
http://www.mediafire.com/folder/5k55aujbcj1gdb0,bc6tto7zc8h6w5d/shared
2019-02-26 21:28:56
Quote #5F by @win2tabless:
for i1002 ,you also can try to reinstall windows os : http://www.mediafire.com/folder/5k55aujbcj1gdb0,bc6tto7zc8h6w5d/shared
Thank you I will try
Do you tutorial how to download widows ?
2019-02-28 03:40:30
Quote #6F by @ahmed hamdy:
Thank you I will try Do you tutorial how to download widows ?
I already reinstall it but the same problem.
Is there is any other solution?
2019-03-01 08:59:09
Quote #7F by @ahmed hamdy:
I already reinstall it but the same problem. Is there is any other solution?
Also I already download win10 image from aldocube official firmware site but the same problem?
Any other ideas?
2019-03-18 19:25:30
Quote #8F by @ahmed hamdy:
Also I already download win10 image from aldocube official firmware site but the same problem? Any other ideas?
I have the same problem. The problem is to initialize the drivers of the sd slot. With an adapter, no probleme to recognize sd cards. I’m desperate
2019-04-15 10:28:19
#10F
This atom dual-system machine, starting from the Z37 series, has the problem of TF card. Either Win system does not recognize TF card after system switching, or Windows system uses high-speed TF card driver after a period of time. If the second case is, you can try to install the old TF card driver.(https://drive.google.com/open?id=1kC5Ldccw9zf2mEsUq9esczE2IVIzR_yp ,this driver for tf card is for win8 ,some person use it can resolve the second problem)
