KizPad Pro
iPlay 50 mini NFE
iPlay 60
iPlay 50 mini Lite
GTBook 13 Plus
iWork GT 12
GTBook 15
iWork GT
Expand X
F40
My Profile
Settings
Login
Global - Engilsh
中国 - 简体中文
日本 - 日本語
Россия - русский
대한민국 - 한국어
Home Page › Forums › Technical Discussion › Root for Alldocube M5X Pro
Tagged: boot, fastboot, flash write failure, M5X Pro, root
I have 2 Alldocube M5X Pro tablets
Model T1006
Kernel version 3.18.60
Android version 8.0.0
Build T1006_V1.01_20200504
One of the two I was able to successfully root. The other however won’t let me flash a new boot.img
The process I’m using is this
I have enabled developper options in Android and turned on USB debugging.
I have enabled OEM Unlock to allow the bootloader to be unlocked
I have used ADB to reboot to the bootloader
I have ran the command fastboot oem unlock … (bootloader) Start unlock flow OKAY [ 7.825s] finished. total time: 7.826s
I have ran the command fastboot flash boot magisk_patched.img where magisk_patched.img is the new boot image I want to flash. This is the result:
C:\adb>fastboot flash boot magisk_patched.img target reported max download size of 134217728 bytes sending ‘boot’ (10253 KB)… OKAY [ 0.468s] writing ‘boot’… FAILED (remote: flash write failure) finished. total time: 0.633s
I am able to flash the ROM through the SP Flash tool for Mediatek devices. But even after flashing a different build, I still get stuck on the remote: flash write failure error.
Can anyone offer any advice on how I could obtain root access on this tablet?
Thank you
I was able to solve this problem by flashing the modified boot.img using the SP Flash tool instead of via fastboot.
After flashing the boot image, the device was wiped and started the Android setup. I was then able to install Magisk Manager and download the zip file, the device rebooted and came back with root access.
In case anyone else is trying to solve this problem, in short, you need the Mediatek VCOM drivers, the Android USB drivers, the SP Flash tool, the stock ROM and the Magisk Manager apk for your tablet. Make sure to backup your data before you start because the device will get wiped.
Extract the boot image from the stock ROM (file is called boot-verified.img)
Install Magisk Manager on the tablet and use it to patch the img file
Connect your tablet to your computer via USB cable
Copy the magisk_patched.img file to your PC
Start SP Flash tool and load the scatter file from the stock ROM
Unselect all the options except for the boot file, click on the path in the location column and select the magisk_patched.img file
Set it to Download Only and click the download button
Shut down your tablet and power it on
This will trigger the download of the boot file. Wait for it to finish and disconnect the usb cable
Power on the tablet
Complete the Android setup wizard
Install the Magisk Manager apk again. It should prompt you that files are missing and ask to download. Accept. This will trigger the tablet to reboot
After boot you can open Magisk Manager again. In the top left of the screen, if you click the 3 horizontal stripes, you’ll find the Super User interface
Hi
Magisk manager don’t ask for install magisk or patch the boot.img
I’m on the build T1006_V1.01_20200504
can you send me the boot-patched.img
thx
The forum ‘Technical Discussion’ is closed to new topics and replies.
Please notice: This form only provides basic technical replies or business consultation. If you have specific after-sales service needs from e-commerce platforms (such as Amazon, AliExpress, lazada, etc.), please be sure to contact the platform you purchased from.
Please choose your purpose: Technical SupportCooperation Inquiries
Your Name:
Your Email:
Product Model (if necessary):
Subject:
Message:
