iPlay 40
iPlay 8T
iPlay 30 Pro
iPlay 20 Pro
VBook
i7Book
KNote X Pro
iWork10 Pro
Expand X
F40
My Profile
Settings
Login
Global - Engilsh
中国 - 简体中文
日本 - 日本語
Community Page › Forums › After Sales Services › IPlay 30 pro does not connect to wifi with no SSID broadcast
In my home network my router is not broadcasting SSID.
Yesterday I received alldocube iplay 30 pro but it cannot connect to the router unless the SSID becomes visible to everybody.
I tried making it visible for the first connection but I cannot make the tablet connect to it automatically when the SSID is not broadcasted.
Can you please help me for this?
This is the first time I see a device forcing this and I assume that this is a bug or a misconfiguration from my side.
When you add hidden ssid, open the advanced options below and change the "Hidden Network" option to Yes
Thank you very much for the support. Problem is solved.
Just a small note that the option is available only when creating a new connection.
When editing an existing one you cannot convert it to "hidden ssid".
