KizPad Pro
iPlay 50 mini NFE
iPlay 60
iPlay 50 mini Lite
GTBook 13 Plus
iWork GT 12
GTBook 15
iWork GT
Expand X
F40
My Profile
Settings
Login
Global - Engilsh
中国 - 简体中文
日本 - 日本語
Россия - русский
대한민국 - 한국어
Home Page › Forums › Technical Discussion › Iplay 10 Pro – After Firmware update does not turn on
I bought today a tablet and decide do a firmware update because have the chinese firmware(without play store). It was working well and haD around 90% battery. So, i updated the firmware using the option Download Only,apparently successfully concluded.
Download Only,
After this the tablet does not turn on.
Firmware: U1006H32GB20104890627
I used this:
P_Flash_Tool_v5.1916_Win.zip
Firmware: iPlay10Pro(U1006)-Android9.0-190704
Hi
I updated my firmware, but by using the files at the download page https://www.alldocube.com/en/firmware/i1002-firmware-download/
That requires a USB stick to put the update files on and you must follow the instructions in the documents to load it, but you will need to be able to power up the tablet.
Does the tablet power up but not boot correctly? on not power up at all? if it powers up but doesn’t boot then follow the instructions from the download site to reinstall the firmware (Android first).
If it doesn’t power up then try this: connect the power supply and plug in the USB-C power connector – leave it connected for 5 minutes to be sure it is charging; then press and hold the power button for at least 20 seconds – it should start to boot. If it boots OK then you’re fine – if it doesn’t then follow the instructions to reinstall the firmware (Android first)
If it still won’t turn on then I think your machine will be useless – try to get a refund if you can.
Good luck!
Steve
The forum ‘Technical Discussion’ is closed to new topics and replies.
Please notice: This form only provides basic technical replies or business consultation. If you have specific after-sales service needs from e-commerce platforms (such as Amazon, AliExpress, lazada, etc.), please be sure to contact the platform you purchased from.
Please choose your purpose: Technical SupportCooperation Inquiries
Your Name:
Your Email:
Product Model (if necessary):
Subject:
Message:
