Home Page Forums Technical Discussion Fine sound setting on AllDoCube X (U1005E)
Viewing 5 posts - 1 through 5 (of 5 total)
MerleOne
2019-09-01 18:42:02
Replies: 4 | Views 2553 | Favorites: 0 | Subscriptions: 1
I have a small issue with my AllDoCube X : I find the sound setting increments to be to large. I mean that with one setting it’s too low and with the next setting is too loud. No “intermediate” setting seems allowed. This is particularly annoying when I use external speakers (JBL Flip 3) or BlueTooth headphones.
Is there a fix or an extra App that could help ?
Thanks.
2019-09-07 10:44:24
so please  show your build number of android os !
MerleOne
2019-09-07 21:50:28
Sorry, here they are :
Android 8.1.0
Firmware build : U1005E_v1.1_20190313
Kernel 3.18.79 (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02))
Hope this helps !
Regards!
2019-09-09 09:56:13
Is your case where the volume is below a value of 50% when the volume is very small, and then plug in the headset or switches the playback, the volume becomes the default volume size (greater or closer to a value of 50%)? If this is the case, it’s just a default logic problem of the system.
MerleOne
2019-09-11 21:17:28
Quote #4F by @win2tabless:
Is your case where the volume is below a value of 50% when the volume is very small, and then plug in the headset or switches the playback, the volume becomes the default volume size (greater or closer to a…
Hi, thanks for the reply. I am not sure to fully understand. I do have noticed that when connecting a bluetooth device, the volume setting cursor sometimes change, but I have to check again…
But my question is actually more general : even if no audio device is connected, either in bluetooth or with the jack, the sound setting increments are wide and only easily activable through the hardware buttons at the top of the tablet. Is there a setting that would offer a more progressive sound setting ?
The only workaround found so far is for video, using a third party application on the Android Store (Google Play Store), a file manager named X-Plore, that has a fine step settings but only for playing videos, doesn’t work for audio only.
Regards,
Merle1
