KizPad Pro
iPlay 50 mini NFE
iPlay 60
iPlay 50 mini Lite
GTBook 13 Plus
iWork GT 12
GTBook 15
iWork GT
Expand X
F40
My Profile
Settings
Login
Global - Engilsh
中国 - 简体中文
日本 - 日本語
Россия - русский
대한민국 - 한국어
Home Page › Forums › Technical Discussion › Alldocube X SD Card Max Size
Hello,
I’ve recently purchased an Alldocube X. I’d like to be able to use an SD card of greater than 128gb so that I can store my FLAC music files on the tablet. I see that the maximum size indicated is 128gb. Has anyone tried using 256gb cards? Not sure if the 128gb is a hardware limitation or just the biggest size confirmed to be compatible by Alldocube. 256gb cards are quite expensive so would rather not buy one until I have some knowledge of whether it is likely to work! Both 128 and 256gb cards are sdxc format, so it should work??
Any thoughts or comments appreciated!
Thanks,
Andy.
I did try on a M5X, and surprisingly, it worked. Everything seems to be alright, but I wont use it that way until officiel confirmation, since nowhere on earth it is said that it works
Please notice: This form only provides basic technical replies or business consultation. If you have specific after-sales service needs from e-commerce platforms (such as Amazon, AliExpress, lazada, etc.), please be sure to contact the platform you purchased from.
Please choose your purpose: Technical SupportCooperation Inquiries
Your Name:
Your Email:
Product Model (if necessary):
Subject:
Message:
