KizPad Pro
iPlay 50 mini NFE
iPlay 60
iPlay 50 mini Lite
GTBook 13 Plus
iWork GT 12
GTBook 15
iWork GT
Expand X
F40
My Profile
Settings
Login
Global - Engilsh
中国 - 简体中文
日本 - 日本語
Россия - русский
대한민국 - 한국어
Home Page › Forums › Technical Discussion › Alldocube X – OTA Update problems
the OTA update of doesn’t work: it shows in the Wireless updates a new version, it is downloading, “install now” and reboot also ok, but it seems that it is not installing, because after reboot is finished same SW version and wireless update is again available…
Anyone got an idea please?
Me too. New update it tries to install is U1005_v1.1_20190313_20190313-1057
If you watch the update, you will momentarily see “Installing system update” and progress bar, then an image of the Android “droid” laying on its side and the word “error” for a few seconds before it reboots automatically. Which means the OTA/wireless update didn’t get applied.
FYI, my Settings –> About Tablet says I have a Model U1005 running vendor-supplied Android 8.1.0 with Build number U1005_V1.0_20190116. I haven’t loaded/flashed any mods — I’m running completely vanilla as delivered by the manufacturer.
Quote #2F by @David Nessl:
Hi. I have the same issue on my european Alldocube X (U1005E). Download OTA 20190313, unpack, reboot in recovery then fails with an ‘error’ message shown on recovery screen. Then reboot in its previous non updated state.
I secured the Android boot on my device with a scheme I have to draw on a 3×3 grid (at each reboot). Maybe this is related ?
all you guys can post pic show recovery.log in recovery mode(recpvery.log can show the detail about error )
Quote #4F by @win2tabless:
i have no idea how to get this log file. if you could explain this to a medium experienced techie, i will try…
just to add, the same happens if you download the update file and start a local update….
It appears that the package’s signature keys don’t match my tablet’s. See attached photo of the recovery.log
Quote #6F by @David Nessl:
so,the pic is your recovery.log.and your tablet android os build number is U1005_V1.0_20190116?
“script aborted : E3001 : package expects build fingerprint” so this is related to what I wrote above (secured android boot with PIN/fingerprint/3×3 grid) ? (I mean secured boot of the OS, not just log in in your personal session)
one more question ,is your android update from build number 20181227 to 20190116,and then update to 20190313?
If this is the case, probably know what caused the upgrade error (1227-0116 OTA package problem). TF packages of 20190116 or 20190108(for u1005e) will be released next week, flash 20190116 or 20190108(for u1005e) TF packages ,and last upgrade firmware to 20190313 version.that may be final sulution.
Quote #7F by @win2tabless:
Yes, that photo is of the recovery.log (while booted into recovery) after a failed wireless update attempt.
And yes, my Settings –> About Tablet says I am currently running Android 8.1.0 with Build number U1005_V1.0_20190116.
Here’s another photo of the log that shows the full error message line (including the keys it is expecting to find).
Is there some way to grab the text version of the recovery logs? If this recovery was TWRP, I’d just boot into TWRP recovery and pull the files via adb.
Please notice: This form only provides basic technical replies or business consultation. If you have specific after-sales service needs from e-commerce platforms (such as Amazon, AliExpress, lazada, etc.), please be sure to contact the platform you purchased from.
Please choose your purpose: Technical SupportCooperation Inquiries
Your Name:
Your Email:
Product Model (if necessary):
Subject:
Message:
