Home Page Forums Technical Discussion Μy M5S is rebooting. some solution?
2019-02-14 02:40:15
Replies: 3 | Views 3629 | Favorites: 0 | Subscriptions: 1
My M5S began random reboots. Any lolution? Thanks
2019-02-23 14:43:50
If it happens randomly, it is not easy to judge the cause.
Please  check if it happens in a specific situation or when a specific app is running.
You can also restore the factory settings to see if it will happen.
2019-02-24 22:59:23
Thanks for your answer @win2tablets. I changed the ROM several times with another ROM, but it is always restarting. But I notice that it gets hot enough without having any other application to run … I suspect it’s a battery issue … due to the heat of the mobile …
2019-02-26 11:37:30
If you suspect that the machine temperature is too high, you can use cpu-z to check the actual cpu temperature of the machine….
The forum ‘Technical Discussion’ is closed to new topics and replies.
